Installing a '67 Parking Brake "Slider" Cover? - NCRS Discussion Boards
  • Ken K.
    • May 31, 1999
    • 235
    I'm looking to replace the black plastic "slider" cover on the parking brake lever. The question I have, how does the slider fit over the handle? If so, how does the black plastic handle come off the chrome lever?
    Thanks Ken
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: Installing a '67 Parking Brake "Slider" Cover?
    A better quesion is where are you going to find and original 67 handle to replace it with? It is not made to be removed, but if you pull out on the button hard enough it will come off and the handle plastic will do the same.Keep in mind that they both may be unusable afterward.
    • Wayne K.
      • December 1, 1999
      • 1030
      Ken,
      As I remember because it has been some time the handle does not come off to replace the plastic slider. There is a break point in one of the ribs so that you can wrap it around the handle. I think I also had to cut some of the length off the end that goes under the shifter console as it wanted to bind up without doing that.
      Wayne
      • Mike M.
        • May 31, 1974
        • 8385
        last one i got from GM was cut thru one of the slots, was longer than necesary and did not require removing the plastic handle. Seems to me i wrote a Restorer article on this subject in the early to mid-90's/ mike
        • Ken K.
          • May 31, 1999
          • 235
          Thanks, Yes I found a photo of the "slider", And it does have a cut in it to go around the handle/lever. Thanks
          • Wayne W.
            • April 30, 1982
            • 3605
            Damn, I missed the point on that one. I thought he wanted to remove the plastic handle.
