C3 Transmission Clutch - NCRS Discussion Boards
  • Gregory G.
    • July 31, 2001
    • 203
    I am looking for a good street clutch for my 1970 LT1 M20 transmission.I am leaning toward Centerforce or Hayes.GM"s 10 spline 11 inch clutch plate, disc and throw out bearing are all discontinued.Any info would be appreciated.
    Re: C3 Transmission Clutch
    A Centerforce II or LuK replacement will do the job for you - smooth engagement, low pedal pressure, great grip. "While you're in there", replace the pilot bushing and have the flywheel resurfaced too - you only want to do this job once
    • Gregory G.
      • July 31, 2001
      • 203
      John,
      Thank you.
      • Mark #28455
        You can also get a RAM stock replacement clutch through SUMMITT. I've used them on my big blocks with good results -m comes as a complete kit for just over $100.
        • Craig S.
          • June 30, 1997
          • 2471
          Make sure you have it all balanced, or you WILL be in there a 2nd time, been there, done that........Craig
          • Gregory G.
            • July 31, 2001
            • 203
            Thanks guys for the info. 3 good choices to choose from ,but alot of work upcoming looking forward to it.
