starter motor #? - NCRS Discussion Boards
starter motor #?
  • Steve Shanks
    starter motor #?
    I was given a good starer from a friend that thought it came off his dads strpped down 67'. The label is hard to read but I believe it is 441001. Could I get some help on this #. The spec book numbers for starters from 63-67 don't come close to this.Thanks ...
    Re: starter motor #?
    Probably a commercial rebuilder's stock number - the Delco number and date will be stamped on the rearward portion of the main armature case, although the case could be from almost anything after going through a rebuilder's process.
