Rivets: WSW Door - NCRS Discussion Boards
Rivets: WSW Door
  • Tony H.
    • May 31, 1993
    • 537
    Rivets: WSW Door
    I am looking for some information on the rivets used on the windshield wiper door of the 1968-72 Corvettes. There is one rivet on each end that secures the moulding to the WSW door. What size rivets are these? Where can I purchase these rivets? How are they installed? Thanks for any info.
    Tony
    Tony
    • 43221
    Re: Rivets: WSW Door
    Tony----
    Subsequent to our discussion of last Saturday and after I returned home, I tried to research the issue of the 68-72 windshield wiper door molding retaining rivets. If you check the AIM, as I expect you have already, you find that it specifies a screw to retain the molding at the ends. I've checked every 68-72 AIM and ALL specify a screw, although 2 different screws were specified over the 5 year's production. No where is a rivet specified. However, rivets were apparently used; my car has the rivets and several 68-72s that I observed on Saturday had the rivets.
    I have checked many old parts books, including Standard Parts Catalogs, and I can find no reference to the rivet and no diagram of a rivet which matches the head design of the ones on my car. Furthermore, I can find no listing for the rivet in any of the vendor catalogs I've checked, including Dr. Rebuild who is usually best for parts like this.
    But I haven't given up.........
      • 43221
      Tony----
        • 15601
        Joe & Tony,
        Check a mill supply catalog. McMaster Carr is one company that comes to mind. These things are called drive rivets and have a screw-like thread on the outside of the shaft, but they are driven in like a nail. I suspect they are pushed in with hydraulic pressure rather than pounded with a hammer.
          • 15601
          Joe & Tony,
          • Chuck G.
            • May 31, 1982
            • 2034
            It seems to me that I have seen these for sale in one of the Corvette catalogs, maybe Paragon or C Central. They are "push in" or "drive" rivets, as Terry states. I'll look.....maybe my memory is failing!! Chuck
            • Chuck G.
              • May 31, 1982
              • 2034
              • Tony H.
                • May 31, 1993
                • 537
                Re: Rivets: 1968-72 WSW Door - Dimensions
                Would someone with original rivets in their WSW door measure the head diameter so I can order the correct size? I did not have my calipers with me in Boston. Also, if someone has the rivets removed, could you give me the other dimensions (shaft length, diameter)?
                Thanks.
                Tony
                Tony
                • Tony H.
                  • May 31, 1993
                  • 537
                  Thanks.
                  Tony
                  Tony
                    • 11643
                    Re: Rivets, Screws or Both, Terry?
                    Terry,
                    Are these then often mistaken as screws, or do people often use screws as replacements, since "both" have threads?
                    Or, were both screws and rivets used over time?
                    Patrick
                      • 11643
                      Terry,
                      Patrick
                      • Tony H.
                        • May 31, 1993
                        • 537
                        I think Terry meant that they are a special type of push-in rivet that has some threads like a screw has. This is similar to concrete nails which have subtle threads but are obviously nails because of their flat heads. Likewise, these WSW door rivets function like other rivets (hold two pieces of sheet material together) and have a round hemispherical head resembling a rivet or nail but are installed by pushing in position like a nail rather than twisting (as a screw). Hope this helps.
                        Terry, please correct me if I butchered what you were thinking.
                        Tony
                        Tony
                        • Tony H.
                          • May 31, 1993
                          • 537
                          Tony
                          Tony
                          • howie miller
                            IF ANY BODY NEEDS THE RIVITS I HAVE ABOUT 20 LEFT. THEY ARE THE REAL THING ,JUST WHAT TERRY DESCRIBED
                            HOWIE
                            • howie miller
                              HOWIE
