59 valve stems - NCRS Discussion Boards
59 valve stems
  • Robert D.
    • April 1, 2003
    • 305
    59 valve stems
    corvette central lists long and short valve stems for my 59 i have hub caps with spinners. can someone tell me which ones are correct
    thanx
    bob
  • Wayne P.
    • August 31, 1975
    • 1025
    LONG *NM*
    • Brad K.
      • August 31, 1990
      • 414
      Re: 59 valve stems
      Bob,
      The '59 judging manual (fourth edition) says (on page 42) that the stems should be 1 1/2 inches long. I presume this means for both 5" and 5 1/2" wheels.
      Brad
      18060
      • Dave S.
        • August 31, 1992
        • 2926
        Re: 59 valve stems
        That is not correct for the 5 1/2" wheels. The valve stem for the RPO #276 wheels is 1" long and a larger diameter than the standard wheel.
        • Ted L.
          • May 31, 1999
          • 101
          Re: 59 valve stems
          Bob,
          The Corvette Central 'long' stems that I have on my '60 are too long and I've been dinged twice for it. They measure 2" long and they should be 1 1/2". You may wish to talk to someone before you order to assure you get what you want.
          Ted
            Re: 59 valve stems
            The "long" CC stems are also too large in diameter to fit through the valve stem hole in a '57 wheel cover - I finally found the right length/diameter stems at a local tire shop.
