1963 muncie - NCRS Discussion Boards
1963 muncie
  • RICHARD CHARLES
    1963 muncie
    does any one know the part # for the front bearing retainer cover of a 1963 muncie 4 speed with a 4 3/16" diameter to fit a # 3788421 bellhousing with the same diameter hole ? thanks
  • William C.
    • May 31, 1975
    • 6037
    Re: 1963 muncie
    604932 group 4.356
    Bill Clupper #618
    • William C.
      • May 31, 1975
      • 6037
      Re: 1963 muncie revised
      Sorry, I gave the T-10 part number, but I believe the muncie used the same retainer in '63.
      Bill Clupper #618
      • Chris D.
        • November 1, 2002
        • 198
        Re: 1963 muncie
        Noland Adams has it as 3790072. Not available from SPO for a long time. It is not listed in my '70 parts book. That will be one rare bird as it only ran for a small portion of '63 only. You may find it easier, if less pristine, to swap to the '64 & later bellhousing so you can use the larger, more common 3915020. Be sure the bolt lengths are right. I forget which retainer had the thicker flange but if you use the long bolt with the thin flange it bottoms out on the gear.
