Rally wheels - NCRS Discussion Boards
Rally wheels
  • Terry Leeker
    Rally wheels
    My '58 came with tires mounted on Rally Wheels. I see in various post, that there are letters or part numbers identifing the wheel to a particular year and make vehicle. I can't seem to find them. Are they under the tires?
  • Ronald D, Rains
    Re: Rally wheels
    test
    • Chuck R.
      • April 30, 1999
      • 1434
      Re: Rally wheels
      Look close to the valve stem. If theres alot of paint on the rims, they might be hard to see.
      Chuck
      • Peter L.
        • May 31, 1983
        • 1930
        Re: Rally wheels
        Terry - Chuck has most likely hit on the answer, as one would generally expect to see the wheel code ( a one ot two letter designation) stamped by the valve stem hole on original '67 and '68 (I'm not sure if it was all the '68 production year) production year rallye wheels and later rallye wheels had the wheel code plus manufacturing location and date information in the same general area. BTW, I have at least one '67 rallye wheel without a wheel code stamp. Also look on the outside face on the webs by the lug bolt holes and you should find a GM stamped on one of the webs and K-H stamped on another. '67 ralleys had the GM and K-H stamping and I think later ralleys did also, so you should be able to tell if it's a Kelsey Hayes wheel made for GM . If I'm wrong someone will send a correction. If the wheels are '67s or '68s, the date of manufacture and wheel size information will be stamped inside the wheel "under the tire." Pete
        • Mike Baker
          For once I can contribute something
          The date stamps began calendar year '68. Wheels made prior to 1/1/68 did not have the date stamped at the valve stem.
          • Peter L.
            • May 31, 1983
            • 1930
            Re: For once I can contribute something
            Mike - Thanks for the confirmation on the '68 wheel external date stamped info. Pete
