C1 Silly putty..... - NCRS Discussion Boards
C1 Silly putty.....
  • Kevin Riel
    C1 Silly putty.....
    Does anyone have a source for the putty or filler that the factory used to fill the holes, such as the one for the front bolt on a door post, or around the nut for the hard top receiver plate on a C1?
    Kevin Riel
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C1 Silly putty.....
    Kevin - I belive the filler for the door bolt was simply bonding compound or close to it. Bondo would probably do quite well. I am unable to address your question about the hard top receiver plate - that leaves me a little confused, but that's nothing new... Best, Dennis
    • Wayne P.
      • August 31, 1975
      • 1025
      I think you want what is commonly called dum-dum. Any body shop supply should have it. Comes in a box of small strips.
      • floyd dossey
        You can also get it at your local Ace hardware store.
        Floyd
        65 Fuelie
        • Calvin M.
          • August 31, 2000
          • 117
          Re: Firewall Insulation
          Hi Kevin -
          If you're intent on using original dum dum, shoot me an e-mail. I've got a wad left over that was in my '57.
          Cal
