more 66 valve cover questions - NCRS Discussion Boards
  • Marzio Cano
    I am trying to decide whether to clean (bead blast?) my aluminum valve covers on my 66 L79 or buy new repro ones. Price is a factor, so is there anyone who has any success/insight in the blasting route or buying repro ones? What's cheaper? Thanks,
    Marzio
  • Wayne K.
    • December 1, 1999
    • 1030
    Re: more 66 valve cover questions
    Marzio,
    If your originals are in good condition other than they don't look as nice as you would like I would tell you to consider having them re-skinned. This is a process that has been highly recommended by others on this board. I am sorry I can't recall who does this but hopefully someone else will respond or check the archives.
    Wayne
      Marzio -
      Send them to Jerry MacNeish ( www.z28camaro.com ) and have them re-skinned; they'll come back looking like this (this is an early staggered-hole low-script cover):
      • Ralph E.
        • February 1, 2002
        • 905
        Marzio,
        DO NOT BEAD BLAST them. Wash and clean them. A little aluminum cleaner maybe!
        How bad are they. Do not polish. If you could, email me a pix.
        I'm not 100% sure, but I think by the time your car was produced the casting flaw was there.
        Ralph #37280
        • Rick S.
          • January 1, 2003
          • 1203
          I also had my 67 aluminum covers done by Jerry MacNeish and highly recommend him.
          Rick Smith
          • Lee Boyer
            John
            I have been thinking of reskinning my valve covers but after seeing the pictures i'm not shure. The orig. finish has a marble look and the pics. don't look to have this, am i not seeing it or what.
            • Larry S.
              • August 31, 2000
              • 356
              I have used mr mac neish on some parts also and they look like brand new peice's when he was finished with them.Mine are not on the car yet but I understand they will remain as new forever?(Is this correct)
              I have had no luck with my bead blaster (regardless of the media I have used to clean aluminum parts)Also the media gets inot every nook and cranny and not so easey to remove.Its especially a problem if using glass beads I would not want that in my motor.No matter how much I vacum and blow it with compressed air it will look perfectly clean of the glass beads.Ill pick the the part I cleaned 2 days latter and find more glass beads.
              I tried naval jelly (took me forever to find it) and I could never get a uniform finish.
              Has anybody been judged with the reskinned parts?
              were there any deductions made?
              • Calvin M.
                • August 31, 2000
                • 117
                Re: More 66 valve cover questions
                Hi All -
                Here's a shot (I hope) of an NOS staggered hole valve cover - no casting flaw - which shows the marble finish referred to above.
                Cal
                • Calvin M.
                  • August 31, 2000
                  • 117
                  Hi again -
                  Please try this link - its another attempt at the picture of the NOS staggered hole valve cover with no casting flaw.....
                  Daftar dan mainkan slot gacor dengan RTP tertinggi hari ini. VIPTOTO, situs terpercaya untuk cuan besar dari slot online!
                  Cal
