ENGINE DATES - NCRS Discussion Boards
ENGINE DATES
  • RICHARD CHARLES
    ENGINE DATES
    DOES ANYONE KNOW THE PROPER TIME BETWEEN DATE CODES ? I HAVE A 1963 327/340 HP. BUILT 04/15/63 ... BUT THE BLOCK IS 12/11/62 IS THIS WITHIN ITS TIME FRAME FOR A CAR BUILT 04/15/63 ???????? THANKS RICK
  • Mike M.
    • May 31, 1974
    • 8396
    Re: ENGINE DATES
    the dec 62 870 block is within the 6 month window that NCRS considers appropriate for the interval between case casting date and car assembly date. however,your example of 4 month window is atypical. i feel real comfortable when the case cast date is 2 two 4 weeks priopr to the cars assembly date. you won't loose any points with a 4 month interval. mike
    • Sydney G.
      • February 1, 1994
      • 444
      Re: ENGINE DATES
      Mike,
      What about the other end of the spectrum? When do you start feeling ill at ease as the gap narrows between the two dates? 10 days, 9, one week?
      My 870 block has a window of I think 8 days between case casting date and build assembly. While some say that this is far too close, I have been shown a top flight car next to mine on the show field that was actually closer than this.
      Richard, my '63 was built May 15, '63.
      Syd
      • Mike M.
        • May 31, 1974
        • 8396
        Re: ENGINE DATES
        Syd: it's not at all uncommon for the casting date just one or two days prior to the machine assembly date. Your example of an 8 day interval between cast date and mach. ass. date is very typical of non-restamped(ie original cases) regards., mike
        • Sydney G.
          • February 1, 1994
          • 444
          Re: ENGINE DATES
          Mike,
          Just as I suspected. As a matter of fact, one of the people who told me that the dates were somewhat to close together was a professional engine rebuilder (and said expert) who also specialises as a custom "restamper"! They advertise in Hemmings.
          Syd
          • Tracy C.
            • July 31, 2003
            • 2739
            Bettcha he offered a fine example of his work
            for sale too.
            More in line with his "ideal window" too of course.
            • Sydney G.
              • February 1, 1994
              • 444
              Re: Bettcha he offered a fine example of his work
              Thats a bet you would have won.
              Tried to tell me that I would be better off with a "safe" casting block so as not to raise any suspicion if I decided to go to Bloomington down the road.
              Claims to have made many top-flight and B.golds in his resume. I just wanted info on rebuild!
              We are the NCRS. If you are going to restore your car as original, like fix the work that Bubba did to your original pad on a 250 hp, and re-stamp it as a 250 horse, document it!! Do not take advantage of these services for personal gain.
              Don't mess with history!!
              Syd
