refinishing aluminum - NCRS Discussion Boards
  • Chris H.
    • April 30, 1990
    • 817
    In one of the Drivelines I read an article on how to use silver paint and a brush to restore the aluminum intake manifold.
    Can someone tell me which date is was in? I cannot find it.
    thanks
  • Rob A.
    • December 1, 1991
    • 2126
    Re: refinishing aluminum
    If I remember the article correctly, it suggested using Krylon dull aluminum paint, dilluted with thinner enought to have just a tint of silver and brushing it in.
    • Len Rayca
      Rob: Wouldn't it have to be high temperature paint?
      • Rob A.
        • December 1, 1991
        • 2126
        I don't remember the article calling for high temp paint. I think the idea was just to leave a slight tint of silver while cleaning the aluminum at the same time, rather than actually painting it. I have had good results using Eagle One brand "etching formula" mag wheel cleaner on the manifold (and other cast aluminum parts) diluted with laquer thinner. Try it on the back side first.
        • Jeffrey S.
          • May 31, 1988
          • 1888
          Chris:
          The article you are referring to was in the Winter 1993 edition of the Restorer. It was written by Bill Halbert. I have used this process on several aluminum parts (aternator and A.I.R. pump) with success but have never tried it on a manifold. It doesn't replace a the professional job but it improves the appearance tremendously.
          Jeff
          • Chris H.
            • April 30, 1990
            • 817
            Re: refinishing aluminum--THANKS NM *NM*
