C-2 --1965 Seat Attachment - NCRS Discussion Boards
  • Denis M.
    Infrequent User
    • July 31, 1990
    • 10
    Achieving Factory appearance for Front and Rear seat mounting. Besides the bolts and brackets in the rear, what else is visible? What is the correct placement and position of reinforcement plates, was the plate under the carpet, or the Jute underlayment? Additional tips, suggestions or comments welcomed.
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C-2 --1965 Seat Attachment
    Is your car an A.O Smith, or St. Louis body?
    • Denis M.
      Infrequent User
      • July 31, 1990
      • 10
      St. Louis, Joe
      • Joe C.
        • August 31, 1999
        • 4598
        Denis:
        For St. Louis bodies, the steel nut plates on the underside of the floorpan, as well as the 2 rectangular stiffener plates, and brackets for the aft mounts are all semigloss black. The mounting bolts are black phosphate, and the seat tracks are gloss black....same as the seat frames (I have heard that some seat track bottom sections, which is, the stationary part that is bolted to the floor, CAN be black phosphate). All hardware, as well as the seats, get bolted directly to the floorpan.
        First, install your underlayment and carpet. Locate the mounting holes by poking tools like awls, Phillips screwdriver, etc., up thru the bottom. Put the seats in position, and mark entire mounting surface with chalk or tailors' marker. Remove seat and SLOPPILY cut out area inside marks, making your cuts WELL inside the marks. At the front mounts DO NOT REMOVE ANY MATERIAL, rather, cut two flaps approx 2" x 2" which hinge from the inboard side of the forward mounts. When these flaps are folded open, they will expose the 4 mounting holes, and the floorpan under the front seat mounts.
        Hard to explain, and sounds complicated. I cannot send you pix. Best thing to do, is look at some cars.
        Joe
        • Denis M.
          Infrequent User
          • July 31, 1990
          • 10
          • Joe C.
            • August 31, 1999
            • 4598
            Denis:
            There are no flaps at the rear mount points.
            Joe
            • Denis M.
              Infrequent User
              • July 31, 1990
              • 10
              Joe,
              Right and thanks again for your imput.
              Denis
