C2 Headlight Limit Switch Function - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2134
    Do "limit switches" open a circuit when the headlight door is fully open?
    Do they do anything when the headlight door is fully closed?
    If not connected, will the headlight door motor work?
    #4889
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
  • Ken K.
    • May 31, 1999
    • 235
    Re: C2 Headlight Limit Switch Function
    First of all it NOT a "limit switch" It does not effect the motor function. All that these two switches do is turn out the "headlight warning" dash light on. If the headlight(s) aren't all the way up this light will flash on the dash.
    Ken
    • Tom D.
      • 2134
      THANKS! That was quick. *NM*
      Michigan Chapter
      Tom Dingman
      • Rob A.
        • December 1, 1991
        • 2126
        There's a "limit switch" on ebay if you're interested...
