I AM WONDERING AS TO HOW MUCH GASOLINE SHOULD BE KEPT IN THE CAR WHEN IT IS ONLY DRIVEN 1 OR 2 TIMES A MONTH AND THEN MOSTLY SHORT DISTANCE. Is it best to put in a few gallons at a time or should you keep it full or mostly full at all times. Does the gas in the tank loose octaine after it sits?should you maybe add dry gas to the tank for condensation purposes?
Thanks in Advance
Tom
Thanks in Advance
Tom
