67 tranny bearing noise - NCRS Discussion Boards
  • Timothy B.
    • January 1, 2004
    • 438
    Just wondering what you folks thought is normal regarding Muncie 4 sp noise. It has always been a bit noisy in gears, but I am specifically wondering about while in neutral with clutch engaged. I have noticed that with the engine idling and in neutral, as I engage and disengage the clutch, that I can hear what sounds like bearing noise coming and going. What do y'all think. How much is normal? Shound I be able to hear the throwout bearing??
  • Scott Marzahl
    Re: 67 tranny bearing noise
    This sounds like the throw out bearing to me. As you engage the clutch, pressure is applied to the throwout bearing, hence the noise you hear.
    • Timothy B.
      • January 1, 2004
      • 438
      The noise I am referring to is present when the clutch is out (tranny in neutral), but not present when the clutch is pressed in.
      • Roy B.
        • February 1, 1975
        • 7044
        Front trans. bearing worn!
