My 1960 stopped running and upon investigating at the carb, no gas was getting to the carb when the engine was turning over. The fuel pump was rebuilt 550 miles ago and there is gas in the tank. I disconnected the steel fuel line from the rubber fuel line at the bottom of the carb and about 2 tablespoons of gas came out of the steel line.
I then moved back to the connection between the frame rail fuel line and the line coming over the side of the gas tank; nothing came out when I disconnected lines. Should gas pour out of the open fuel line by gravity flow? or do I have a plugged strainer assembly inside the tank? or does gas flow thru the lines only when the fuel pump is working properly?
