C2 Wiring Question? - NCRS Discussion Boards
C2 Wiring Question?
  • Ralph E.
    • February 1, 2002
    • 905
    C2 Wiring Question?
    At the proportioning valve on a 67 Corvette their is a wire for Low fluid warning. How does can the wire connector be removed so that the routing could be changed. Don't want to break anything an it seem a bit fragile. Bubba has it hanging under the clutch push rod.
    Ralph #37280
  • Ralph E.
    • February 1, 2002
    • 905
    Re: C2 Brake System Warning Light Switch
    Correction. The wire is connected to the "Brake System Warning Light" switch under the master cylinder. How is the wire connector removed?
    • Wayne W.
      • April 30, 1982
      • 3605
      Just a simple plug in with a boot. Pull on it.
      • Ralph E.
        • February 1, 2002
        • 905
        Wayne, you were right on. I pulled real hard and off she came. Thanks.
        Ralph #37280
