OEM spark plugs - NCRS Discussion Boards
OEM spark plugs
  • Warren F.
    • December 1, 1987
    • 1516
    OEM spark plugs
    I am looking at some spark plugs on ebay. They are AC 443XLS, GM# 5613395.
    Are these a correct application for a '71 LS6 application?
    Thanks in advance for replies, Warren
  • Mark #28455
    Re: OEM spark plugs
    No. They will work but were not factory equipment on the LS6. They were the over the counter performance plug.
    • Warren F.
      • December 1, 1987
      • 1516
      Thank you... Mark *NM*
        • 15680
        Re: OEM spark plugs
        "Performance plug" doesn't mean you want to run it in a street engine. "Performance plugs" are typically just like the OE plugs, but a colder heat
        range, which makes them suitable for extended high output, such as racing.
        For street driving you need a relatively "hot" plug because you spend very
        little time at full load.
        The OE plugs meant for "town and country" driving are a bit on the cold side,
        and most Corvette engines operate better (less tendency to foul plugs)
        by using one heat range hotter than OE.
