'56 '57 Correct battery placement - NCRS Discussion Boards
  • Rex Kelly
    I was looking at the picture on page 58 of the battery setup in my 1956 1957 NCRS Technical Information and Judging Guide, and the picture appears to be incorrect in that the "forward" arrow is pointing the wrong way. The battery in my '57 has the negative post on the inward or motor side and forward of the yellow battery caps. Is this correct?....thanks
  • Roy B.
    • February 1, 1975
    • 7044
    Re: '56 '57 Correct battery placement
    Yes ! you cant believe every thing you see.
    • John P.
      1956-57 Team Leader
      • April 30, 1992
      • 64
      Rex,the copy on P58 of our manual is correct, the battery picture on P58 of our Tech Info. manual and Judging Guide was evidently picked up from the picture in the 1956-1957 assembly manual Sec. 12, Sheet 2.00, note the date of this drawings entry is 9-15-55.
      • Rex Kelly
        John, thanks for your response....I took the page to the car to compare... and you are absolutely right as usual. In my feeble mind, I was picturing the tray inside the frame thus making the picture look backwards...Thanks again...Rex
        • Robert D.
          • April 1, 2003
          • 305
          Just got done doing that used a good heat gun and laquer thinner
          P.S. rather poke my eyeballs out then do that again
          Good Luck
          BOB
