Soft top Assy C1 only read -Trivia - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    There is some confusion by some owners as to how they would determine a 56 to 59 or late 59 to 62 soft top frame assy. to buy.
    1. 56 to 59 frame pic. at right is a long "one" piece plate ( it's the one that can bend easy )
    2. late 59 to 60 frame pic. at left is a short "two" piece plate (also the same plate used in 61 to 62)
    3. Only difference in 61 to 62 is that the rear bow has a recess for the soft top lid.(hump)
    4. any year soft top assy may or may not have a stud on the right side lower bracket where the frame mount to the body. It's for a attaching the safety arm for a power top option.
    I don't know if the repro assy being sold have this difference ??
    5. And remember that the soft top latches are different then the hard top are , the reason being that the headers are different that meet the window.( that was an Article I wrote about many years ago )
    If the two repro's guys out there that are selling the soft top assy. ( noting the difference) let me know.
    PS the Article said 56 to 58, it was wrong.
    Also the header weatherstriping for the soft top , was a one piece starting from above the middle window L/S to the middle window R/S for 56 to 59.Which is not being repro-ed , only the late 59 up are.
  • Dennis C.
    • June 30, 2002
    • 884
    Re: Soft top Assy C1 only read -Trivia
    Roy,
    Is it worth trying to find an original soft top frame to restore, or would you recommend going with a repo?
    Dennis
    • Roy B.
      • February 1, 1975
      • 7044
      Give me two choices , a clean pretty repro for $2,000 ? or a REAL original used with some dust and dirt for $3,000 and I'll come up with the $3,000 every time. Again I don't know that the repro is correct? and cant imagine it is. But that is me and I don't judge other people that disagree.
      • Dennis C.
        • June 30, 2002
        • 884
        Thanks, Roy *NM*
