Picking this up again from Monday's post...After replacing the front brake lines and manually re-bleeding, the car still pulls to the left. I did notice that there was sediment in the jar that I bled the brake fluid into Sunday and I'm assuming that wouldnt be that unusual. In the 16 or 17 yrs I've owned the car I've never touched the master cylinder, and my guess is that there's probably a fair amount of particulate floating beteween the mc and the calipers. Tomorrow I'll pull the calipers and see if there is any leakage that wasn't visible when assembled. Other than leakage, is there anything else to look for to identify what the problem could be? These are Dr. Rebuild SST calipers that are ~10 yrs old but with only a few thousand actual miles on them. Maybe at this point the best thing is to replace them.
Thanks, Gary
Thanks, Gary
