C3 electrical conectors - NCRS Discussion Boards
  • Brandon Metzger
    Is there a place that sells the electrical connectors. I am looking for the male and female connectors ... say for example the connectors that hook up the seat belt warning system. I believe thay are always black and they come in different sizes. The hack that had my '72 before felt they were not needed so he just cut them off and tossed them. So I have the passanger side seat belt warning system missing a few and the courtesy light in the rear storage compartment missing one and God knows what else.
    Any help is greatly appreciated.
    Thank you,
    Brandon
    '72 BB
  • Dick W.
    • 10483
    Re: C3 electrical conectors
    The last time that I looked in the GM Standard Parts Catalog, there were several connectors listed. I am not sure that since that everything has gone to the weatherpak type connectors that they are serviced any more by Generous Motors. Joe Lucia should have the answer there. AMP has quite a few listed in their catalog.
    Dick Whittington
      • 11651
      I've had good luck buying small connectors like these from Eagle Wire Products.
      • William C.
        • May 31, 1975
        • 6037
        Also, don't overlook the opportunity for a junkyard excursion. Most C-3 wiring "bits" were used on other GM vehicles of the era, and may be salvaged from a Chevy, Buick, Olds, or Pontiac with similar features inh terms of option content, seat belt warning for example.
        Bill Clupper #618
          • May 31, 2002
          • 169
          I spent $456.15 with Eagle Wire Products, for a a/c harness and dash harness
          with a/c & seat belt wiring.
          There number is 1-800-977-0030. Satisfied customer.
          They probably can sell you a partial connector etc.
          I needed harnesses after my car caught on FIRE while in a repair shop.
          Shop was a Mr.Knowitall. The little shop of HORRORS. Slidell-Louisiana.
