Need carb help La area - NCRS Discussion Boards
+ More Options
Posts
  • Tony DiGiorgio
    Hello All,
    Have a power with my tri power set up in my 69 435. Lots of popping and misssing. Told it may be a power valve, does anyone one know an ncrs memeber in Los Angeles area or good old school mechanic who can help me with this. Thanks in advance, Tony
  • Jim T.
    • March 1, 1993
    • 5351
    Re: Need carb help La area
    Tony a test that I have used on my Holley when I suspected a power valve failure is to remove the air cleaner and with the engine running put a finger over the vertical fuel bowl vent. If the engine starts to stumble, die after a several seconds, it has been my experience that the power valve was leaking or ruptured.
