Hydraulic Clutch Conversion - NCRS Discussion Boards
  • Michael H.
    • July 31, 1998
    • 180
    If you're not concerned about originality, check out the article I wrote in the recent issue (April 2004) of "Corvette Enthusiast" magazine on converting from mechanical clutch linkage to hydraulic clutch release bearing. You can eliminate all the cross bars, springs, bosses, etc. and free up a lot of space in the engine bay. If you'd like, I can send you a copy of the article in Adobe format if you provide me with your e-mail address.
    Mike
  • Michael Jones
    Re: Hydraulic Clutch Conversion
    Mike:
    Another advantage is that the hydraulically-actuated clutches are so much smoother than conventional clutches practically eliminting that annoying "clunk" you experience when you're not quite "on" with the clutch timing. I once owned a Pantera that had a hydraulic clutch and it was smootn as silk!
    Mike
    • Pierre J.
      • July 31, 2000
      • 193
      For what year?
      • Michael H.
        • July 31, 1998
        • 180
        I installed the hydraulic clutch release bearing in my '63, but I believe it will work for any Muncie or Saginaw transmision. Check with Howe Enterprises website to make sure.
