Tri power end carb float bowl part number? - NCRS Discussion Boards
  • William Holder
    Hello All,
    Anyone know what the Float bowl part number is for 3659 Holly end tripower carb?
    My Holley book says it is not serviced.
    Is it different from the standard seconday center pivot dual inlet float bowl used on most Vac Secondary 4 barrel carbs? They would use part number 134-102.
    Again according to my Holley catalog. Any Help would be greatly appreciated.
    Thanks in advance
    Bill
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Tri power end carb float bowl part number?
    the secondary float bowl from a non doublepumper will work. that is the correct # if you have striped the threads in your orignal there are places that can repair them
