C2 Powerglide to Turbo 350 conversion - NCRS Discussion Boards
  • Ed McGettigan
    My Uncle took out the 2-speed Powerglide transmission from his 1966 coupe and replaced it with a 3-speed Turbo 350 transmission. All went well except that he cannot shift into the low gears (1 and 2). It shifts fine between Park and Drive.
    Any thoughts on how to resolve this so he is able to shift in gears 1 and 2?
  • Roy B.
    • February 1, 1975
    • 7044
    Re: C2 Powerglide to Turbo 350 conversion
    Your shifter DETENT is different, the shifter bracket on the side of the trans.could be turned %180.
    • Michael S.
      • April 1, 1987
      • 364
      Shifterworks in NY makes a shifter detent for this conversion. This will allow the use of all three gear settings.
      • Ed McGettigan
        Shiftworks is mailing the necessary conversion parts! Thanks for your hel!!!
        Ed
