Engine Code Suffix markings on Block - NCRS Discussion Boards
  • Brian Monticello
    As I was cleaning up my block I found these markings - it wasn't until I flipped the engine over that it made sense. The stamp pad shows HC and the markings on the side of the block must have been an assembly line marking.
    This isn't a Corvette block but it is used in a Corvette. I thought i'd share these pictures for anyone that was interested.
    stamp pad picture showing HC:
    • 43239
    Re: Engine Code Suffix markings on Block
    Brian------
    The yellow crayon-applied engine suffix code in the location that you have found is very common on original Flint-built small block engines.
    Depending upon date code and other factors, this engine is a 250 or 275 hp 327 from the 65-68 period or a 250 hp 350 from 1969.
    • roland verrico
      I read your post and remembered being told that the HC code in 65 being for a full size passenger car.Let me know what you find out. Thanks.
        • 43239
        Roland-----
        The "HC" engine suffix coe was used for full size passenger cars with 250/275 HP engines from 1965 through 1967. It was not used only for 1965.
        • roland verrico
          Thanks for the reply, now just so I understand correctly the HC was not used in corvettes only passenger cars.
            • 43239
            Roland-----
            The "HC" suffix code was not used for Corvettes.
            • roland verrico
              Thanks Joe, that is what I had been told in the past but wanted to be sure I heard right.
