Powerglide ID - NCRS Discussion Boards
Powerglide ID
  • Willard M.
    • August 31, 1979
    • 422
    Powerglide ID
    What can tell me if a powerglide is for a 53-54 Corvette? What is different that would mean its from a Corvette and not just a passenger car? Currently its hooked up to a six with numbers 3835499 E232. Sounds to me like May 23, 1952-am I correct?I haven't seen the block, but no suffix letters seem to be present.
    Bill #2659
  • Mike M.
    • May 31, 1974
    • 8396
    Re: Powerglide ID
    a 50 to 54 chevy pass car PG will have a tailhousing to accept a torque tube rear end. the 53 and up Corvette powerglides were open rear end/ open drive shafts and hence the vette tailhousing will accept a slip yolk which would in turn accept a conventional open drive shaft u_joint. also the 56 up vette trailhousing will have provision to mount a shifter on the tailhousing. mike
    • Roy B.
      • February 1, 1975
      • 7044
      Re: Powerglide ID
      The Corvette out put shaft is shorter ( car out put shaft won't work in a Corvette) and the Corvette has a open drive shaft. Also the shifter linkage indicator L/S is different for the safty switch ( has a hole for the rod)those are the easy way to tell.
      • Bernard M.
        • August 31, 1994
        • 341
        Re: Powerglide ID
        Mike, I'm not familiar with very early Corvette Powerglide applications. I knew that 53-54 shifters mounted to the body and not to the transmission, but was not sure if the 55 was the same. I take it from your post that the tailshaft of a 55 Powerglide would NOT have shifter mounting bosses, and the shifter would mount to the body like a 53-54. I ask because I have given information regarding the availability of a Corvette Powerglide tailshaft to someone. The transmission is asserted to be a 55, but has mounting bosses on the tailshaft housing. I don't want to misdirect someone who is trying to get his car together right.
        • Roy B.
          • February 1, 1975
          • 7044
          Re: Powerglide ID
          The 55 had NO mounting boss on the tail housing, the shifter was mounted on the body tunnel as was 53 to 54.
          • Chris S.
            • January 1, 2000
            • 1068
            Re: Powerglide ID
            what are the correct part numbers and id's for 54 transmissions ?
            1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
            Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
            1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
            1957 Corvette - FI 3 sp - Black and Silver
