Having a problem getting the radiator out. I have followed instructions in the service manual but I can't seem to clear the lower outlet. I can't get the fan shroud to fall forward enough to pull it straight out. I even removed the fan & clutch assembly and that didn't help much.
I don't want to remove the support assembly if I don't have to. However, if I have to remove the support assembly are there any precautions I should take?
