62 340 oil pan - NCRS Discussion Boards
62 340 oil pan
  • Chris H.
    • April 30, 1990
    • 817
    62 340 oil pan
    I tought I would show the picture of the oil pan that I have off my 62 340 hp. How about everyone go out and drop your oil pan and take the same picture so we can compare:)
    It has 3 pcs bent 90 degrees.
    (this is first time I have tried to insert picture, lets see if it works)
    Chris
  • Tom D.
    • September 30, 1981
    • 2135
    Re: 62 340 oil pan PHOTO HINTS
    ...just guessing here.
    Be sure to put your photo on a "web available" place. There are several "photosites" - some cost $5 per month after a free start up period. Or, have a friend place them on a web site and ref. the file location on the site, which ends with .jpg or the like. Use the full address (cut and paste from the web file list).
    If you ref. the site PAGE (on which you see the photo) just put that address in the text of your message (not where it says photo in the box below). Example of this www.midvette.homestead.com
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    • Tom D.
      • 2135
      Forgot to Mention - RIGHT CLICK
      If you point to your photo and click with the right side button on your mouse, you will see a list which includes the word "properties" near the bottom. If you select that and hit enter (or click on it), a window will open on your screen that shows where the ncrs.org computer is looking to find your photo.
      I did this on your photo box (not showing up as a photo for me) and I cannot explain why your file ref. did not work. Perhaps the photo is no longer where you referenced...
      Tom D.
      NCRS - MI Chapter Site
      Michigan Chapter
      Tom Dingman
