59 245hp spark plugs - NCRS Discussion Boards
  • Robert D.
    • April 1, 2003
    • 305
    what are the proper plugs for a 59 245hp (2 4 barrels) ive read r44 and r43s
    thanx bob
  • Donald L.
    • September 30, 1998
    • 461
    Re: 59 245hp spark plugs
    According to the manuel "Corvettes Technically Speaking" all 59 Corvettes used
    AC 46 .
    • Dave S.
      • August 31, 1992
      • 2926
      The 1959 owners manual calls for all 59 cars to use AC46 for city driving and AC 44 for town and country driving. Also AC C43 COM for heavy duty and high output and AC C42-1 COM for extended and extreme high output. Plug gap
      .033"-.038". I'd use 46's in and FI car and 44's or 45's in all others.
        • 15695
        Most long time small block owners agree that regardless of HP rating, the AC 45 is the best all around heat range for normal driving, but AC has deleted this non-resistor plug from stock.
        The current alternate is the AC R45, a resistor type. You could also run the extended tip verion - R45S, NGK and Denso offer
        a non-resistor equivalent to the 45, B4 and W14-U respectively and Denso's W14P-U is equivalent to the out-of-production 45S.
        There is anecdotal evidence that extended tip plugs can interfere with the domes on SHP engines, but if your 283/245 has OE or equivalent pistons, they do not have domes.
