C1 59: Transmition part check - NCRS Discussion Boards
  • Rob M.
    NCRS IT Developer
    • January 1, 2004
    • 12784
    Hi,
    The housing of my 4 speed shifter states T10-7D casting 8819490.
    I can't find these numbers in Noland's restoration & technical guide. Is this a correct shifter since I suspect this to be a Hurst shifter ?
    greetingsa and thanks for your response,
    Rob Musquetier
    The Netherlands.
    Rob.
    NCRS Software Developer
  • mikemccagh
    Re: C1 59: Transmition part check
    t 10 7 B is appropriate for a 60 and 61 vet, t 10 7 A is waht you need for a 58 or 59 t-10. . Hurst shifter not a factory item . repo 4 speedf shifters are available and of good quality. mike
    • Larry Parylla #41143
      I saw the shifter on your web site, it is wrong for the car The ball chould be white, yours is white with a black center piece showing the shift patern on it. It should also have a "T" lever the needs to be lifted to shift to reverse. It is to prevent an accidental shift to reverse.
      • Dave Suesz
        59 shifter
        Rob- The shifter in your car looks like a Hurst or Hurst clone. The original had a "T" slide to prevent accidentally shifting into reverse.
        Paragon 59-62 repro shifter
