C2 Engine Rebuild Need Advice - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Mobile, AL availability
    sleeving cost between $80/$100 a hole including the sleeve
    • Chuck S.
      • April 1, 1992
      • 4668
      Boy, did I get some bad info or I misunderstood...$900 must have been for all eight holes.
      • Clem Z.
        • January 1, 2006
        • 9427
        chuck you just live in a rent district *NM*
        • Bob R.
          • June 30, 2002
          • 1595
          Re: Radiator condition?
          Jerry
          The radiator is a Dewitts I purchased it new last summer. The fan and clutch are correct for a 63. I had the clutch rebuilt last summer. I have an old temp sender which is accurate when checked against a infared tester. I did find an air pocket in the upper hose above the thermostat. I believe that caused some of the problem. I believe I have corrected that. The water pump is 2 years old and seems to work properly. All hoses and belts have been replaced.
          When I attended a car show last summer the outside temp was 90 degrees. My engine reached a temp of 240 degrees. I little too hot for my liking. I did not blow out any antifreeze though.
          This summer I'll see if the air pocket was the problem. If you have any suggestions I would welcome the advice.
          Bob R
            • May 31, 1974
            • 8385
            less than 80 per cyl to sleeve here in cumb, md. we also have a special on snow at this time . two bits a ton, we load , you haul. mike
            • Clem Z.
              • January 1, 2006
              • 9427
              mike if i wait till spring do i get a better price on the snow as i have enought of my own right now.
              • G B.
                • December 1, 1974
                • 1407
                Bob -
                With a couple of exceptions, you've done all I can think of to cure the problem. I've dealt with the following head-scratchers that you may want to consider if your car gets hot this summer.
                I haven't had much long term luck with rebuilt fan clutches. Yes, they're "correct" and pretty, but they don't work and last like a new GM fan clutch. (For $150 each, the new GM version better work right.) The same goes for rebuilt water pumps. I won't use them. I buy new Stewart pumps. I drill a small hole in all the thermostats I install to aid air removal. And lastly, I've got one I know you don't want to hear. Sometimes I've had to manually clean out the rust scale and hard deposits clogging the lower water passages in blocks that have spent a long time sitting. This is even after a week of machine shop tanking to clean a bare block.
                • Gary J.
                  • April 1, 1980
                  • 1242
                  Less than 50 miles from me in Greer,SC we have a guy making snow. Image that???
                  Here is his web site. www.ceremuga.com
                  Gary Jaynes
                  NCRS# 3503
                  • Dick W.
                    • 10483
                    #24
                    If you are not losing water, you should be ok. I would do an accurate temp test with a good infared tester. BTW, I can ship you plenty of snow, you just pay the freight. And gonna git more tommorrow.
                    Dick Whittington
