3782608 water pump spacing - NCRS Discussion Boards
  • Ian S.
    • June 30, 2002
    • 264
    Hello,
    Does anyone know the distance from the block mating surface to the front of the hub face for 327/300hp with this water pump?
    Ian
    • 43240
    Re: 3782608 water pump spacing
    Ian-----
    It should be 5-9/16". However, if your waterpump pulley uses an internal reinforcement (attached or not attached to the pulley), then you MAY require a dimension of 5-7/16".
