C1 891 parts vendor - NCRS Discussion Boards
C1 891 parts vendor
  • Ted S.
    • January 1, 1998
    • 747
    C1 891 parts vendor
    Where can I get parts for a '58 891 distributor? Specifically I need the clamps that hold the distributor cap, lead wire, and grommet. TIA
  • Terry D.
    • May 31, 1987
    • 2691
    Re: C1 891 parts vendor
    Lead wire and grommet are available from Paragon or Corvette America. The clamps I have not seen, doesn't mean they are not available, you might try the endors that have used parts, Paragon, Mary jo, Grossmueller's to name a few. Otherwise it's off to the swap meets and junkyards.
    • Ted S.
      • January 1, 1998
      • 747
      Terry, have you purchased the grommet from either vendor and if so is it correct? From the pics it looks like it is for the single point dist where the wire comes through the bottom (i.e. round rather than square like the 891 which comes out the side). Thanks Ted
      • Roy B.
        • February 1, 1975
        • 7044
        Re: C1 891 parts vendor Hay TED
        Like Bernard said and me ,do you care if the engine gets oil to the top? I have a 56 Dist. if you care.
        • Ted S.
          • January 1, 1998
          • 747
          Roy, I saw the other posts on the 265 and the issues with using an 891. This is for a '58 283. I can find the lead wire in most of the catalogs/vendor sites but I can't find the grommet or the clips that hold the cap on. Any suggestions on where to get 'em? By the way the '56 looks sweeet in the Restorer.
          • Roy B.
            • February 1, 1975
            • 7044
            Ted sorry I thought your engine was a 265 , I have what you need, wire grommet and clips. But it's going to cost you BIG-A-BUCKS E-mail me.
