C-1 Distributors - NCRS Discussion Boards
C-1 Distributors
  • Steve H.
    • November 1, 1996
    • 118
    C-1 Distributors
    Hi all, Could anyone tell me what differences (if any) there are between a '56 # 1110879 and a '57 # 1110891 distributor? There seem to be a lot of #891's around and not so many #879's. I wondered if I could use a #891 that I have on my 56 225HP. I would also like to use a breakerless ignition set up but they only list them for 1957 and up with distributor caps having windows.
    Thanks in advance.
    Steve
    ps- I finally recieved my driveline today!
  • Mike M.
    • May 31, 1974
    • 8388
    Re: C-1 Distributors
    the 891 will fit but , on the judging field, its lack of a vac advance canister will raise eyebrows . keep looking for the 56 with vac advance as well as centrif advance. mike
    • James F.
      • December 1, 1985
      • 596
      Re: C-1 Distributors Steve & Mike
      Steve,
      Mike meant to say, it will fit fine on your 225HP and judges will not blink an eye because your '56 225 HP engine did not come with vacuum advance! Regards,
      • Roy B.
        • February 1, 1975
        • 7044
        No ! you have a 265 engine . The cam has a relief cut out at the back lop , the crank rear bearing has one oil hole at the top, the #879 Dist. bottom side is flat.
        The 283 engine cam is not cut,rear main bearing has two oil holes, Dist's have no cut out.
        The 265 engine is like no other V8 engine.
        • Mike M.
          • May 31, 1974
          • 8388
          jim's correct. i was thinking of the 869 distrib. i'm slowly loosing it boys. mike
          • Bernard M.
            • August 31, 1994
            • 341
            I have to agree with Roy. Do not use a 891 carb on a stock 265 engine. The top of the motor will not oil. There is a significant difference in the casting at the base of the shaft on ALL distributors used in 265s that include a flat area and an extra oil hole. 225HP engines used either a 872 or 879 distributor, depending on when built.
            • Bernard M.
              • August 31, 1994
              • 341
              And obviously ...
              when I typed carb, I was thinking distributor.
