Hypothetical C2 Judging Situations - Any Hope? - NCRS Discussion Boards
  • Joe S.
    • July 31, 1999
    • 319
    A couple of maybe dumb questions I'd like to run by someone who's been there - done that?
    Does a car that has non-original ball-joints that are riveted on, get the same deduction as a car that has non-original ball-joints that are bolted on?
    Same goes for tie-rod ends and idler arm. If non-original, is there the same point deduction as if they are non-original, and have a shot of cast blast or something on them to prodcut them from the elements/rust.
    Lastly, if the only deductions so far are for the above items and perhaps a couple of minor ones here and there, and the original rear, driveshafts, halfshafts and tranny also have a shot of cast blast or something on them, would it still be possible to make Top Flight. (Oh yea, also, I don't want to smudge up my engine and exhausts manifolds with overspray and orange paint either).
    All major components of the car are the correct part/date codes. All hardware has the correct finish and headmarks. The car will be painted with lacquer. However, wear items (Brakes and steering mainly) I am replacing for safety sake as I plan to drive the car.
    Like I said, maybe a dumb question, but do I have a chance? I'd like to have the car judged and this site and the judging manual have been invaluable to me in my project so far. But I'm at a junction where I need to make some final decisions that will have longer term impact.
    ps: I realize there are many areas I could loose points on and until the car is actually judged these are all just as the subject line says, "hypothetical" (if I spelled it right ;-)
    Joe's 63 FI Convertible
  • Mike M.
    • May 31, 1974
    • 8385
    Re: Hypothetical C2 Judging Situations - Any Hope?
    rivited will get more positive points than hex head bolts .tie rod ends, regardless of cast blast finish, will be jugded on configuration or morphology. as long as the shape/morphology/configuration is identical to originals, finished in cast blast isn't gonna kill ya on the judging field. sounds like your car will do fine and a top flight isn't out of the question.mike
