1970 LT-1 swaybar size - NCRS Discussion Boards
  • Jeremy D.
    • November 1, 1998
    • 323
    Does anyone know if the 1970 LT-1's had the small block or big-block swaybar in the front (none in the rear)? My car has a 7/8" bar in the front, but I thought I read somewhere that LT-1's should have the big block bars (1" or so).
    • 15677
    Re: 1970 LT-1 swaybar size
    As far as I know the LT-1 was equipped with the base suspension 3/4" front anti-roll bar unless the LT-1 was installed as part of the ZR-1 package, in which case it would have the Z-06/F-40 15/16" front bar and 550/305 lb/in F/R springs Later in the seventies, after the demise of BBs and as the Corvette got heavier, the base suspension bar was increased to 13/16".
    Big block base suspension cars received a 7/8" front bar and a 9/16" rear bar.
    It sounds like your car has a BB base front bar, which would reduce roll and increase understeer.
    Nailing down the bar sizes can be tricky as the three above bars are only 1/16" different. Measure the bar in at least three locations in areas that have minimum forming to be sure you determine the correct size.
      • 43221
      Jeremy-----
      I agree with the information provided by Duke and can confirm that the 3/4" front bar was used for 1970 LT-1 unless the LT-1 was supplied as part of the ZR-1 package.
      • Jeremy D.
        • November 1, 1998
        • 323
        Thanks Guys!! *NM*
