Inside of Rear Bumpers Rusty on1969 - NCRS Discussion Boards
  • Allen N.
    • Today
    The outside of my rear bumpers look great, but the insides are rusty. What is the best thing way to restore them?
    Allen
    • 43222
    Re: Inside of Rear Bumpers Rusty on1969
    Allen-----
    Rust on the inside surfaces of these bumpers is VERY common. If you want to clean them up, I think that your best bet is to clean them with a wire wheel on a drill as best you can and clear coat them for longer-term protection. Although I've never used the product this way, you might try a coating of a product called "Extend" before you clear coat. This will render any rust you don't get with the wheel "inert" and "stabilized".
    You could also use a chemical rust remover (acid-based product like Jasco Metal Etch), but if you do this you may also remove whatever chrome is present.
      • May 31, 1974
      • 8391
      joe and allen: regarding Extend, a product i've used for years. its a super product that works super to prevent rust. i use it on all battery trays before i paint them . However,if allen intends to have the c-3 judged, the Black/charcoal color that is inherent with EXTEND will be frowned upon as the unexposed surfaces on the c-1 thru early c-3 bumpers were of a silver color. not sure if they were silver by virtue of their "fresh" raw sleel or whether they actually got a shot of silver-like paint. nonetheless, i always blow a thin coat of argetnt silver rally wheel paint on the unexposed surfaces of said re-chronmed bumpers on cars i'm having judged. if you go with Extend., let it dry overniote, then blow a thin film of rally wheel silver over the dried Extend. mike
      • Allen N.
        • Today
        Thanks Joe and Mike! *NM*
        • Dennis A.
          • April 30, 1999
          • 1010
          Allen...
          After wire wheeling, I masked the bumpers and spot-blasted all the areas the wheel could not reach. This worked great and spraying with the Rally wheel paint has left them in good shape going on four years now.
          • Richard P.
            • July 31, 1995
            • 57
            Allen,
            Another product you might want to consider is Cold Galvanizing Compound. Its made by Rustoleum as an aerosol. It is described as a "zinc rich coating" It dries to a dull metallic finish.Its available from industrial supply houses. Be careful of the fumes. I coated the inside of my bumpers 3 years ago and have not seen any rust. The method I used was to spray some in the bumper creating a puddle then rocking and rolling the bumper to coat all exposed metal.
            Just my $.02
            Rick
