69 Headlights won't pop up - NCRS Discussion Boards
  • Tom B.
    • February 1, 1994
    • 779
    Re: 69 Headlights won't pop up
    Tom,
    Great. I'm glad your solution was a simple one. Tom #24014
    • Tom B.
      • February 1, 1994
      • 779
      Tom,
        • 15606
        #18
        Chuck,
        Tony and others are giving you good info, but a picture is worth a lot. See me at a meet & I'll show you. how to lower them. I am glad Tony decided to try with words, because I was at a loss.
        To all: be careful of the micro switches for the headlamp warning system. They are tempting to use to raise and lower the headlights, but they are plastic and break easily.
          • 15606
          #19
          Chuck,
          • Chuck G.
            • May 31, 1982
            • 2034
            #20
            Thanks Tony and Roberto; I tried both ways and they both worked. It was really pretty easy once I learned where to "push". Thanks to both of you. Chuck
            • Chuck G.
              • May 31, 1982
              • 2034
              #21
                • 15606
                #22
                Chuck I guess you will not need me to show you now.
                I'm heartbroken!! :-)
                  • 15606
                  #23
                  • Chuck G.
                    • May 31, 1982
                    • 2034
                    #24
                    Hi Terry; There are at least several thousand other tricks that you can show me! You've forgotten more about these cars than I'll ever know. Thanks for all of your help. Chuck
                    • Chuck G.
                      • May 31, 1982
                      • 2034
                      #25
                      • Dennis M.
                        • April 30, 1988
                        • 160
                        #26
                        Chuck,
                        I bet Terry to the punch and will stop by next door and show you, when I get home. It is simple. Your neighbor and Corvette friend.
                        To others,
                        Chuck and I were researching this problem on my '68 and I found that there are two other possible problems areas wher you can create a vacumn hose problem. Both can be the result of working on some other area of the car. First, I took out the washer bottle to clean and when I replaced it, I knocked loose the headlight hose connection under the passenger side fender well. Second, I replaced the turn signal switch and when reconnecting the wires and adjusting placement, I knock off the vacumn hose for the wiper door. Good luck.
                        • Dennis M.
                          • April 30, 1988
                          • 160
                          #27
                          Chuck,
                          To others,
