58 interior firewall - NCRS Discussion Boards
  • kenneth bingener NCRS#38563
    Early 58 w/ red interior. My firewall has evidence of red overspray on the firewall INTERIOR insulation likely from painting the heater/radio console. Is this factory or bubba? If bubba, any tips on paint concoction to restore black insulation finish appreciated. I was thinking on thinning out some semi gloss or flat black to make a "stain" type paint. Thanks, Ken
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Put the cuffs on Bubba... *NM*
    • Mike M.
      • May 31, 1974
      • 8388
      Re: 58 interior firewall
      flat charcoal close to original but even then judges will probably pick up the painted or as you state, stained cardboard insulation. the cure, replacing the insulation, is a rather extensive fix and one i do when i've got a vette torn down for full restoration. that is the ideal time to replace the firewall insulation but you could sucessfully tackle the problem at this point. . good luck, mike
        Thanks Guys! Gotta go cuffin' *NM*
