1959 block 739 or 519? - NCRS Discussion Boards
  • Pat #25912
    About when did the 519 block replace the 739? The TIM&JG only says;
    "1958 & Early-1959........3737739"
    "Late-1958 through 1960...3756519".
    Does "early" and "late" refer to the calendar year or the model run?
    If calendar year, then I read it as between aprox. Dec 1958 and Jan 1959.
    If model year, the I read it as aprox. June 1958 to Sept 1958.
    Or is there a typo and it should say "Late-1959 through 1960" anf if so I am really confused.
    My car has an approx build date of Jan 30 1959 and would like to know what is correct before I start my search for a block.
    Thanks in advance. Pat G.
  • Loren L.
    • April 30, 1976
    • 4104
    Yours is a 519 *NM*
    • Pat #25912
      Thanks Loren *NM*
      • Bill B.
        • September 30, 2002
        • 351
        Re: Thanks Loren
        Pat, now I am confused which does not mean much. I know of a Flint 519 block having been cast June 30, 1958. As I understand things, this motor could be "technically" accepted for 1958s July, 58 to end of 58 production and then possibly to Dec, 1958 on the 1959 models. So, I would think that should you stumble across a Flint 739 block with a casting of July 30 or later--you could have possibly had a 739 in your car too. Thought I have been told that motors are accepted upto 6-months within build--who told me this? I wouldn't pass a 739 by if it fits! Does anyone know the last casting date of the Flint 739? Regardless, bet it is a lot easier to find a 519 in your 59s situation.
