C3 1972 T-Top Bags Date Code - NCRS Discussion Boards
  • john wilson
    Are the date codes on the two T-top bags usually the same date.
    The dates on the bags that came with the 3/72 Corvette I
    purchased from 3rd owner are 7/71 & 9/71. I was curious
    I these could be orginial.
  • Warren F.
    • December 1, 1987
    • 1516
    Re: C3 1972 T-Top Bags Date Code
    My '71 bags read this way exactly..
    MAR 3 1971 on both bags
    • Rich G.
      • August 31, 2002
      • 1397
      The original bags with my July 18 built 68 are both marked "5 68"
      Rich Giannotti
      • john wilson
        Do your bags have any other marking. Mine have " t/t " approx 3/4 in letters
        • Roger Legge
          My '68 #2511x has both dated 5/68. Both are fairly faint and the stamp is, best I can descibe briefly, a squished six sided format (sorry for the bad description). Both have the date format as "5-68" (minus " marks). If the bag was facing with the opening towards you, one has the stamp on the flap, almost centered between the velcro gizmos, and the other has a more faint stamp, way offset to one side, upside down relative to the other and inside the bag as opposed to being on the flap. The squished six sided outline is a double line arrangement, meaning two squished six sides, one inside the other, about 1/4" or so between the two. Both have the "5-68" quite a bit offset towards the bottom of the six sided doo dah. I do not see anything other than the 5-68 and the double lined six sided outline, but they are both fairly light stamps.
          Roger
          #36316
          • Warren F.
            • December 1, 1987
            • 1516
            Both bags have a stamp "t/s" marking about 3/4 of an inch in red ink. My date codes are also in red ink.
            One bag has only these two stampings one time. The other bag has these two stamping only once also, but in addition has another stamping several times in various spots that is AT 71 once and T 71 several places, these are in black ink, and a much larger letter stamping.
            My '71 is a Apr 20 build date
            • Charlie P.
              • July 31, 2003
              • 260
              My July 12 build 1971 has large black "3 AT 71" and small red "April 26 1971" stamps on the bags. As to your question, hopefully some T-Top bag expert out there knows what should be expected as far as proximity to car build date and commonality of dates on the two bags.
              • Rich G.
                • August 31, 2002
                • 1397
                Roger.
                You desribed the bags I have exactly. I was too lazy to go into all that detail.
                Rich Giannotti
