65 Door Hinges - NCRS Discussion Boards
65 Door Hinges
  • John O.
    • June 30, 2000
    • 88
    65 Door Hinges
    I'm almost ready to reinstall the door hinges/doors on my 65 roadster. I cleaned and blasted the hinges. I know they will get hit with body color during painting but before that what level of black paint is appropriate (semi-gloss, gloss) if any. Mine had evidence of the zinc-chromate primer on the flat mounting surfaces and seemed to be black also except for the areas hit by the paint. Anyone have a recommendation on this?
    Thank you,
    John Osterholm
  • Wayne W.
    • April 30, 1982
    • 3605
    Re: 65 Door Hinges
    I think that they should be zinc chromate. At least the AOS cars were.
    • Mike M.
      • May 31, 1974
      • 8389
      Re: 65 Door Hinges
      agree with wayne: all c-2's, regardless of st. louis or a o smith, were zinc chromate green underneath the body color. mike
      • John O.
        • June 30, 2000
        • 88
        Which Zinc Chromate To Use
        Should I use the real thing which seems to be available from aircraft related suppliers or use the Quanta product, which I believe is just really a paint. What would be the best for judging purposes?
        Thank you,
        John Osterholm
        • kelly theaker
          Re: Which Zinc Chromate To Use
          I thought Z/ chromate was used on the birdcage , you may have this evidence on the portion of the door hinge that bolts to the hinge post / or did the hinge recieve the primer as well ? . I do believe if your going to be spraying the posts and hinges that you should use the correct materials and not just for the color out of a spray bomb, i sugest you build for life and not short term
          • Gene M.
            • April 1, 1985
            • 4232
            Good boating supply stores carry the green zinc chromate and zinc phosphate (more EPA acceptable) in spray bombs and quarts. PPG makes a catalized green primer/sealer that has great protection properties and looks exactly like the original birdcage green.
