C2 Big block Exhaust Manifold Bolts - NCRS Discussion Boards
  • Blake W.
    • April 30, 2001
    • 164
    Do the inner exhaust manifold bolts (4 per side) that bolt the exhaust manifold to the head have lock washers or not? These are not the bolts with the french locks. C2 big block.
    thanks Blake
  • Kieran A.
    • April 30, 1987
    • 87
    Re: C2 Big block Exhaust Manifold Bolts
    Blake,I believe the washers are used only on the front and rear bolts to allow proper spacing for the french locks; the four center holes do not utilize the washers. The washers are thick spacer washers,not lock washers, placed between the manifold and the french lock. Regards,Kieran #11373
    • Blake W.
      • April 30, 2001
      • 164
      thanks for the reply Kieran. I'm aware of the spacers on the french locks. My question is if the center 4 bolts use any kind of washers, ie a split washer ect???
      • Rob A.
        • December 1, 1991
        • 2126
        The center 4 bolts have no washers, lock washers or spacers.
        • Kieran A.
          • April 30, 1987
          • 87
          Blake,Rob hit the nail on the head;nothing on the four inner bolts. Regards,Kieran #11373
          • Blake W.
            • April 30, 2001
            • 164
            Thanks to both of you. Exactly what I needed to know.
