C2: BB distributor cap heights - NCRS Discussion Boards
  • Dan Pepper
    After rebuilding the distributor, replacing valve springs and clutch, I began having problems with the rear of the hood interfering with the top of the distributor sheilding wing nuts. This was called to my attention when I noticed that the shield wing nuts were digging into the underside of the hood (ouch). I know the tolorances are close under the hood because I once used a 1/4" spacer-gasket under the carb - and the air cleaner rubbed the underside of the power bulge. Figure the clearance is probably the same for the back of the hood/distributor housing.
    The only thing I can think of that has changed since doing all the work was that I replaced the dist. cap with a new Neihoff (sp?) cap. I'm using lectric limited wires, so the wire config. should be correct. I tossed the old cap, so I don't know if the height of the new cap is taller, and is causing the interferance. Do new caps spec'd for '66 corvette 427's come in different heights? If yes, can anyone suggest a brand that they know will fit under the shielding correctly?
  • Mike M.
    • May 31, 1974
    • 8385
    Re: C2: BB distributor cap heights
    Doubt the cap the problem. my guess is the ignition shielding mounting points are higher off the engine than previously. if you can get the ing top shield attached to the ing shielding main body and still have interference then doubt cap the problem.See if you can't tweak on the left and right ing shield main body mounting brackets. good luck, m mike
    • William C.
      • May 31, 1975
      • 6037
      Cap heights were the same, '62-74 except FI cars that used the D-310 dap
      Bill Clupper #618
      • Dave S.
        • August 31, 1992
        • 2925
        I'm not familiar w/ mid year details but C1 cars have chrome bolts in lieu of wing nuts holding the upper shielding thus allowing a bit more clearance on the top.
