54 Corvette Engine ID - NCRS Discussion Boards
  • Richard P.
    • April 1, 2001
    • 42
    54 frame #E54S004635 has engine 0I67247 F55YG. What could this engine have come from?
    • 43238
    Re: 54 Corvette Engine ID
    Rick------
    I believe that "YG" is some sort of truck application, but that's all I can tell you.
    • Wayne P.
      • August 31, 1975
      • 1025
      If I'm reading your post correctly this would be from one of the very RARE 6 cylinder 1955 Corvettes!!
      • John P.
        1956-57 Team Leader
        • April 30, 1992
        • 64
        Rick, out of curiosity what is the casting date on that block. Located on the passanger side rear near the starter solenoid. Should be a letter for the month and a number for the year.
        • Dave Suesz
          NCRS JG says...
          Some late '54's had a "55" pad stamp, and high VIN tended to have high serial on the stamp. Check the casting dates- You just might have the ORIGINAL engine. Imagine that, a C1 with the original engine.
