66 DASH PADS - NCRS Discussion Boards
66 DASH PADS
  • steve #34143
    66 DASH PADS
    WHAT IS INVOLVED IN REPLACING BOTH DASH PADS?? THE PASENGER SIDE DOES NOT LOOK TO INVOLVED,THE DRIVERS SIDE IS WHERE IM NOT SURE IF THE DASH CLUSTER HAS TO COME COMPLETELY OUT ???????? ANY INFO WOULD BE APRECIATED...THANKS STEVE
  • Mike M.
    • May 31, 1974
    • 8385
    Re: 66 DASH PADS
    Not only gotta loose the cluster but i think you'll find it much easier to replace the pads once you have the entire dash assembly on your workbench. good luck, m ike
    • Pat #25912
      Re: 66 DASH PADS
      Hi Steve. If you'd like, I could fax you a copy of the instructions that came with the dash pads I put in my '66 a couple years back. E-mail me your fax number if you want them. Pat G.
      • Charles M.
        • March 1, 2002
        • 155
        Re: 66 DASH PADS
        Pat - Could I have a copy too? I have dash work coming soon. 813-612-9133 - 8AM - 5PM only. Attn Chuck. THANK YOU!
