C2 - '67 battery cable - NCRS Discussion Boards
  • Tom Merkel
    On a '67 L-79 (no air), is it correct for the negative battery cable to be about 18" long, and curl downward, and attach to the frame (approximately) directly underneath the battery?
    Thanks.
    Tom
  • William C.
    • May 31, 1975
    • 6037
    Re: C2 - '67 battery cable
    Look at the AIM, UPC 12, Page A-6, the neg cable is connected to the outboard starter bolt, along with the wiring harness ground wire at the same bolt.
    Bill Clupper #618
