'67 E-BRAKE HANDLE RELEASE BUTTON - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    The release button on my e-brake handle keeps coming out, along with the spring. How is this supposed to be retained, and can I repair mine?
  • Chuck G.
    • May 31, 1982
    • 2034
    Re: '67 E-BRAKE HANDLE RELEASE BUTTON
    If it's like 68's and 69's, the square button is pressed/glued, and/or heat sealed over the release shaft. They're hard to get off. I've taken a few handles apart. As I recall, the release shaft is "gnurled" to aid retention. Try epoxy or superglue. Chuck
    • Rob A.
      • December 1, 1991
      • 2126
      I looked in the handle with a light and see the shaft you mentioned. I'll glue it back on with PC7 epoxy, great stuff. Thanks...
